I have just purchased a radeon 9200 128meg grafix card and it is slower than my 64meg 9000. i am running a gigabyte P4 titan motherboard, 768megs ddr 266 ram,windows xp pro, 1.7gig P4 celeron chip. wot is wrong? please help
tests on 3mark2001 were:
Did you adjust the display settings at all regarding the benchmark? Did you change the performance of the card in the ATi control panel? Those are a couple of things that could easily distort the 3dmark score.
Hey
Make sure you have completely removed every single trace of the 9000 drivers from your system otherwise you can get some major problems…you can download PowerStrip with that link I provided for you and check your clock speeds to see if they meet default clock speeds…250MHz Core/400MHz Memory. Gl!
later
