Help choosing video card
I’m about to get a new video card next week, and i’m just swamped with loads of different manufacturers and models that are all about the same price, and don’t really understand the differences between them.
So anyway, I’ve narrowed it down to these few:
  • Gigabyte GTX 260 Super Overclock Series, 896Mb GDDR3 448bit, Core Clock : 680MHz, DVI+VGA+HDMI, PCI-X 2.0
    (price 1350 kn)
  • Sapphire HD 4890 Vapor-X, 1GB GDDR5 256bit, Dual DVI+HDTV out (price 1450 kn)
  • Sapphire HD 4890 OC, 1GB GDDR5 256bit, Dual DVI+HDTV out
    (price 1500 kn)
  • MSI N275GTX TwinFrozr OC,896 DDR3,448bit
    (price 1400 kn)
I’ve been looking at some performance charts and on some tests one is better, on some another one.
Which one do you think I should get? Using this PC for gaming mostly.
Thanks in advance!
P.S. If it’s not a problem could someone try and couple it up with a good enough PSU to required for the card, because I think I’ll have to change that aswell :S
