I built my first rig and when i turn it on it works, but at the end of booting vista up i get blue screen of death and it reboots. What should i do? increase the woltage and stuff?
asus p5n 780i deluxe
1gbx1 ocz reaper
xfx 9800gtx
700w OCZ gamexstream psu
what does it say on the Blue Screen? However, it just seems like something must have gone wrong during the instillation, so your probably just going to have to re-instal Vista.
bad install most likely possible bad drive… i found that just installing vista off a usb key is much faster try that avoid nasty mistakes after all it is vista
