Where is the best place to buy RAM and what RAM is compatible with my system?
[/quote]
i only buy Corsair RAM now, you can use PCWizard to identify you current RAM
an antec TP2 and i would have thought a 450W or a 500W antec would probably be ok
i’m not comfortable recommending grfx card, as i don’t know enough about the grafx market
[QUOTE=matttibb]
DDR2 4300 (266 MHz) DIMM
yes, but what is the CAS rating
Edit:
it is easier if you know the type, speed & brand, it is possible to use different RAM speeds together but all the RAM in that system will only run at the speed of the slowest RAM installed (e.g. i have 2 DIMMs of DDR 1 stick of 512Mb PC2100 (333Mhz) and 1 stick of 256Mb PC2100 (266Mhz) i can use any PC2100 that has the same CAS rating, irrelevant of the speed, but a system always runs the RAM at the slowest speed of installed RAM[ot]my system runs my RAM at 266Mhz, because my DIMMs have the same CAS rating[/ot]
have a read through the DDR Sticky
That’s extremely cheap for a 600W, especially considering that’s the normal price and not after discounts and rebates. I wouldn’t touch it. A Hiper 350W, which isn’t top-tier, like PC Power & Cooling is only a couple Pounds cheaper…Your money, but I wouldn’t recommend it. If your buying on that site, this Hiper 530W does cost more, but a good power supply is never a bad investment. That Novatech house unit may work fine, but why risk it?
Ok well I’ve installed another GB of RAM and everything seems fine. Now just waiting for my spanking new graphics card and psu to be delivered tomorrow
The waiting is annoying. It’s being delivered today but it’s already 2:25pm and still not here. I bet it’ll get here and the 8800GTS won’t fit in my tower.
