OK so i have a computer case that supports 20+4 pin connector, but im thinking about getting a new motheboard which has to have a 24 pin connector. Would my 20+4 pin case support the motherboard, or am i going to have to get a new case
thanks
thanks
no you don’t need a new case, check this and if you don’t want to use the adaptor you could just get a compatible PSU
