Help, not sure if my video card died
hi everyone
I have a dell dimension 4700. I installed a new graphics card about 3 years ago and i had to put it in a different slot. My technician guy told me to put the monitor plug-in in a different slot closer to the bottom than the default one at the top of the back of the computer..
So i was just using my computer like i do any other day, and all of a sudden my monitor turned black. I turned my computer off and restarted it but it was still black. I check to see if my monitor is unplugged but it isnt so i finally decide to try it on the default slot and now it works. The graphics definitely seem shittier now and i checked the Direct X diagnostic tool. It says im using the video card that came with the computer, an intel blablah bahl. It used to say the nVidia 6200 geforce.
So what do you guys think the problem is? And input would be nice. Thanks ahead of time.
