Hello, I’ve just installed dragon 8 software. My problem is when ever I use it a little box pop up to tell me to activate code now, or I will have only 4 more chance to use the software. Everytime I press activate it seem to go through internet, but then I start dragon again and out pop the same box telling me to activate now.
Try and see if theres an alternative way to activate it. Most activation software allows you to activate by calling a toll free number which you say/type your product code and it gives you an activation code.
Thanks, I try it Monday morning.
Well I think online is better way to activate the program because I’ve used the phone system to activate the windows and its like pain in the ass coz you have to tell a hell long to number to them and then in return they will do the same. They will give the hell long number to enter into your system.
