I made this computer tonight, im almost sure i have all the peaces i need. im almost sure i asembled it the way it had to be (im not that of a newb ^^) and… IT DOESNT WORK AAAA, its a BEAST:
2gb kingston
2.40ghz 64 fx-53
x800 ati radeon 256mb
300gb hd
asus sk8v MB
HELP HELP HELP!!! when i power it up the screen stays black and the fans turn on, the fans are on, but NOTHING happends!
HELP!!!
Yeah, not many power supplies that come with cases could power your hardware. YOu need moh powah. Atleast a 400watt name brand power supply. Antec, sparkle, fortron, thermaltake, enermax, ultra. The thing is not has many watts it puts out, is how many amps the power supply puts out
Take the gfx card out, assuming you have an on board one. Take the ram out to just one stick. Basically minimise the components and see if it boots up then.
If it does, then it either means you have faulty hardware, or not enough power.
here are the specs:
2.40ghz 64 fx-53
2gb ram
x800 pro
300gb hd
audigi 2 pro something
480 (just checked and its 480) watts powersuply from startech.com aka the reactor
That’s a recent guide on some basic motherboard troubleshooting. What you want to do is take the motherboard out of the case and lay it on a flat, non-conductive surface…like the box your motherboard came in. Use the minimal amount of components you need: the CPU and CPU heatsink, motherboard, 1 stick of RAM, and the video card. Make sure you’ve hooked up all power connectors on the motherboard and the video card (if there is one on that). Go with the guide above and this basic configuration and take it from there.
