hi all aint been on in a awhile..
ive now completely built my system:
Amd “Barton” 333 2500+ Thermalright SLK-900A
Asus A7N8X Deluxe nForce2
Corsair 1GB DDR XMS3200C2PT TwinX (2x512)
ATI radeon 9600XT 256mb sapphire
16x NEC Dvd
120gb Serial ATA 7200rpm 8mb Seagate Barracuda
Antec Plus 1080AMG Metallic Gray File Server Case - 430W + 5 internal fans
Its a brilliant system, and i’m glad i asked alot of questions on these forums ![]()
im currently downloading 3dmark on my slow connection
to test my system out ![]()
other than saying thanks.. i have a problem..
i’ve cleaned up my old system:
Duron 1.3ghz / 640mb Sd 133 / ATI Radeon 8500 64mb
16x DVD / 12x CD-RW
SoundBlaster Value Live!
put everything in a new beanie transparent case added some extra leds and illuminuse fans and cables and given it to my younger brother as his 1st pc for xmas.
basically.. i dont have time 2 play alot of games, and when i do i play CS i’ve started teaching my brother how to play CS, as ive been playing it for almost 4 years, but with my old duron the grphx r really slow…
on my brothers pc:
i run at: 800x600 ingame with 16bit colour detail / opengl
with 3.9 drivers. i constantly get around 30fps. and on occasion if i just stop and look at a sky or a wall i will get 50 - 99fps. but as soon as i start moving it goes no higher than 30fps.
now it doesnt really bother me, as my new card gives me 100fps constant ingame. but i believe that the radeon 8500 64mb should be able to get atleast 50fps constant.
when i brought it i was told that i’d easily get 50fps with it. 40 minimum.
ive turned everything to performance, vsync is off.
Desktop is: 1024x768 @ 32bit @ 84.9hz
Running: WinXP Pro
is it the rest of the durons system that is laggin me?
