Hi guys. I’m having some problems with my liquid cooling system. It’s a ThermalTake BigWater system. Apparently, it is supposed to bring the cpu down to 30 Degrees. But MINE IS 66!! And it keeps rising. What is wrong? The radiator is working. The pump too. I can’t find a reason why it’s not working. Please help guys. Thanks. :ohah:
Is water flowing freely to the CPU? Also is the CPU water block mounted firmly and securely
Yes. Everything is in place. But the temperature continues to rise.
is the voltage for the CPU, FSB, Multiplier all set correctly? Also, you could check if the actual CPU is heating at all and the temps aren’t just false values. If you can keep your fingers on the block firmly without pain you should be fine.
