Help with my Asus A7N8X-E
ive got a 3000+ 400fsb and whenever i start to play a game i get a voice error from my motherboard that says System Failed CPU Test im not understanding why could someone please help me
The first thing I’d do is install the latest drivers for your chipset and your games.
See if it helps.
i have but it still does it
Check your temps and voltages.
CPU Temp = 44 C
MOBO Temp = 16 C
+12V = 12.224
+5V = 4.919
+3.3V = 3.312
VCore 1.68
All Statuses are OK
this is really pissing me off
Try resetting the bios default options and make sure the cpu is at its default speed also.
You can also run Memtest86 to see if your memory is faulty somehow. Faulty memory can cause weird problems.
Memtest86 where do i get this?
www.memtest86.com
