I have a patriot 3070 laptop and recently it wont turn on.
I press the power button and it loads up as normal untill it comes to a page.
It gives me the options such as start in safe mode.. Start windows normally…
etc.
I have tried each of these repeatidly and all it does is take me to the “Windows” Loading screen before Showing a blue screen for a split second thean cutting out.
As I Am young I am not very experienced with computers and have no idea what is wrong with it.
well just boot from XP CD and when prompted try repair, failing that reinstall XP over your existing instalation (remembering [COLOR=“Red”]NOT to format, if you have data on the drive you wish to keep)
It’s very common practice to have a restore CD if you really hose your XP install, and some boutique builders include a copy of Windows.
As long as you have your Windows CD key (it’s typically on a sticker on your laptop somewhere, likely the bottom), you can use someone elses copy of XP to install on your system. Just make sure you use your CD key, not theirs (or it can cause problems).
