I recently had to unstalled powerdvd5 because it stop working
I reinstalled it and it work fine except for I try to use the capture button it said captured
but when I try to look for the picture that I capture I can’t find it. Can
you tell me what wrong
When you press the capture button, are you asked where you would like to save the file?
If you are not asked where you would like to save the capture, then it is probably being saved in the clipboard. Therefore you will need to open a program such as Microsoft Paint, click the edit menu, and click on paste. Your image should appear then.
try looking in these places…
Just look in the folders of Power DVD…Like in vidio folder or clips because sometimes they save it in their default folder.
Doccuments → Videos
Cheers
[QUOTE=Karanislove]
Doccuments → Videos
Cheers
Good idea Karanislove, I think you are 100% right there. Some programs do have their own folders for screenshots, videos, music etc.
Try looking in My Documents > Cyberlink > PowerDVD
