help with ram upgrade
i am planning to buy a 1gb ddr1 ram pc400 but i don’t if my motherboard can support this ram. Can a p4m266a-8235 support this memory?
[code]--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version                                           EVEREST v2.20.405
Homepage                                          [Lavalys - Comprehensive IT Security and Management](http://www.lavalys.com/)
Report Type                                       Report Wizard
Computer                                          OM (my computer)
Generator                                         Administrator
Operating System                                  Microsoft Windows XP Professional 5.1.2600 (WinXP Retail)
Date                                              2008-07-03
Time                                              10:58
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
  Motherboard ID                                    04/15/2003-P4M266A-8235-6A6LW00HC-00
  Motherboard Name                                  VIARAMA U8668 (Pro)
Front Side Bus Properties:
  Bus Type                                          Intel NetBurst
  Bus Width                                         64-bit
  Real Clock                                        100 MHz (QDR)
  Effective Clock                                   400 MHz
  Bandwidth                                         3200 MB/s
Chipset Bus Properties:
  Bus Type                                          VIA V-Link
  Bus Width                                         8-bit
Motherboard Physical Info:
  CPU Sockets/Slots                                 1
  Expansion Slots                                   3 PCI, 1 AGP, 1 CNR
  RAM Slots                                         2 SDR DIMM, 2 DDR DIMM
  Integrated Devices                                Audio, Video, LAN
  Form Factor                                       Micro ATX
  Motherboard Chipset                               P4M266
Motherboard Manufacturer:
  Company Name                                      Biostar Group
  Product Information                                http://www.biostar.com.tw/products/mainboard/index.php3
  BIOS Download                                      http://www.biostar.com.tw/support/bios/socket.php3?socket=775
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
  Total                                             255 MB
  Used                                              188 MB
  Free                                              66 MB
  Utilization                                       74 %
Swap Space:
  Total                                             1259 MB
  Used                                              374 MB
  Free                                              884 MB
  Utilization                                       30 %
Virtual Memory:
  Total                                             1514 MB
  Used                                              563 MB
  Free                                              951 MB
  Utilization                                       37 %
Physical Address Extension (PAE):
  Supported by Operating System                     Yes
  Supported by CPU                                  Yes
  Active                                            No
Problems & Suggestions:
  Suggestion                                        Install more system memory to improve applications performance.
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Samsung M3 68L1713DTL-CB0 ]
Memory Module Properties:
  Module Name                                       Samsung M3 68L1713DTL-CB0
  Serial Number                                     F207FAD2h
  Manufacture Date                                  Week 7 / 2003
  Module Size                                       128 MB (1 rank, 4 banks)
  Module Type                                       Unbuffered
  Memory Type                                       DDR SDRAM
  Memory Speed                                      PC2100 (133 MHz)
  Module Width                                      64 bit
  Module Voltage                                    SSTL 2.5
  Error Detection Method                            None
  Refresh Rate                                      Normal (15.625 us), Self-Refresh
Memory Timings:
  @ 133 MHz                                         2.5-3-3-6  (CL-RCD-RP-RAS)
  @ 100 MHz                                         2.0-2-2-5  (CL-RCD-RP-RAS)
Memory Module Features:
  Early RAS# Precharge                              Not Supported
  Auto-Precharge                                    Not Supported
  Precharge All                                     Not Supported
  Write1/Read Burst                                 Not Supported
  Buffered Address/Control Inputs                   Not Supported
  Registered Address/Control Inputs                 Not Supported
  On-Card PLL (Clock)                               Not Supported
  Buffered DQMB Inputs                              Not Supported
  Registered DQMB Inputs                            Not Supported
  Differential Clock Input                          Supported
  Redundant Row Address                             Not Supported
Memory Module Manufacturer:
  Company Name                                      Samsung
  Product Information                               [SAMSUNG Semiconductor](http://www.samsung.com/Products/Semiconductor/DRAM/index.htm)
[ DIMM2: Samsung M3 68L1713DTL-CB0 ]
  Serial Number                                     F201FA4Ch
  Module Width                                      64 bit
Memory Timings:
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00:  VIA VT8751(A) ProSavage P4M266(A) Chipset - System Controller
  Offset 00:  06 11 48 31  06 00 30 22  00 00 00 06  00 08 00 00
  Offset 10:  08 00 00 E0  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 48 31
  Offset 30:  00 00 00 00  A0 00 00 00  00 00 00 00  00 00 00 00
  Offset 40:  00 18 88 80  82 44 00 00  18 99 88 80  82 44 00 00
  Offset 50:  E8 5F EF 88  64 85 10 10  66 00 08 08  10 10 10 10
  Offset 60:  0A 2A 00 20  E6 99 00 27  CF 4D 86 50  40 04 00 00
  Offset 70:  82 C8 00 01  01 01 10 00  01 00 00 00  00 00 00 00
  Offset 80:  00 61 00 00  C0 B8 00 00  02 00 01 00  00 00 00 00
  Offset 90:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset A0:  02 C0 20 00  07 02 00 1F  04 01 00 00  2D 92 04 00
  Offset B0:  78 AC 10 9B  40 00 E8 FF  68 00 00 00  00 00 00 00
  Offset C0:  01 00 02 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset D0:  00 00 00 00  00 00 00 08  22 00 22 00  70 38 02 00
  Offset E0:  00 00 00 18  00 00 89 00  40 00 00 00  00 00 00 00
  Offset F0:  00 00 00 00  00 00 81 00  00 00 00 00  00 00 00 00
B00 D01 F00:  VIA AGP Controller
  Offset 00:  06 11 91 B0  07 01 30 22  00 00 04 06  00 00 01 00
  Offset 10:  00 00 00 00  00 00 00 00  00 01 01 00  F0 00 00 00
  Offset 20:  00 E6 F0 E7  00 E4 F0 E5  00 00 00 00  00 00 00 00
  Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  00 00 0C 00
  Offset 40:  83 47 00 44  24 72 00 00  00 00 00 00  00 00 00 00
  Offset 50:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 60:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 70:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 80:  01 00 02 02  00 00 00 00  00 00 00 00  00 00 00 00
  Offset A0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset B0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset C0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset D0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset E0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset F0:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
B00 D10 F00:  VIA VT83C572 PCI-USB Controller
  Offset 00:  06 11 38 30  07 00 10 02  80 00 03 0C  08 20 80 00
  Offset 10:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 20:  01 D0 00 00  00 00 00 00  00 00 00 00  06 11 38 30
  Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  0B 01 00 00
  Offset 40:  40 12 03 00  00 00 00 00  00 0B 00 00  00 00 00 00
  Offset 60:  10 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 80:  01 00 C2 FF  00 00 00 00  00 00 00 00  00 00 00 00
  Offset C0:  00 20 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset F0:  00 00 00 00  00 00 00 03  00 00 00 00  00 00 00 00
B00 D10 F01:  VIA VT83C572 PCI-USB Controller
  Offset 20:  01 D4 00 00  00 00 00 00  00 00 00 00  06 11 38 30
  Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  03 02 00 00
B00 D10 F02:  VIA VT83C572 PCI-USB Controller
  Offset 20:  01 D8 00 00  00 00 00 00  00 00 00 00  06 11 38 30
  Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  0C 03 00 00
B00 D10 F03:  VIA USB 2.0 Enhanced Host Controller
  Offset 00:  06 11 04 31  07 00 10 02  82 20 03 0C  08 20 00 00
  Offset 10:  00 00 00 E8  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 04 31
  Offset 30:  00 00 00 00  80 00 00 00  00 00 00 00  05 04 00 00
  Offset 40:  00 00 03 00  00 00 00 00  A0 10 00 89  00 00 00 00
  Offset 50:  00 5A 00 80  00 00 00 00  04 0B 88 88  53 88 00 00
  Offset 60:  20 20 01 00  00 00 00 00  01 00 00 00  00 00 00 C0
B00 D11 F00:  VIA VT8233A/VT8235 PCI-ISA Bridge
  Offset 00:  06 11 77 31  87 00 10 02  00 00 01 06  00 00 80 00
  Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 77 31
  Offset 30:  00 00 00 00  C0 00 00 00  00 00 00 00  00 00 00 00
  Offset 40:  44 00 F8 0B  00 00 00 00  8C 20 00 00  04 00 0A 08
  Offset 50:  81 1D 09 00  00 B0 C3 50  43 00 00 00  00 00 00 00
  Offset 60:  00 00 00 00  00 00 00 04  00 00 00 00  00 00 00 00
  Offset 70:  06 11 77 31  00 00 00 00  00 00 00 00  20 00 00 00
  Offset 80:  20 84 59 00  F2 30 00 00  01 04 00 00  0A 18 00 00
  Offset 90:  F0 1F 02 88  20 C0 0D 00  00 00 00 00  00 00 00 00
  Offset D0:  01 05 01 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset E0:  00 00 00 00  04 08 00 00  00 00 00 00  00 00 00 00
  Offset F0:  00 00 00 00  00 00 07 00  00 00 00 00  00 00 00 00
B00 D11 F01:  VIA VT82C571 IDE Controller
  Offset 00:  06 11 71 05  07 00 90 02  06 8A 01 01  00 20 00 00
  Offset 20:  01 DC 00 00  00 00 00 00  00 00 00 00  06 11 71 05
  Offset 30:  00 00 00 00  C0 00 00 00  00 00 00 00  FF 01 00 00
  Offset 40:  0B F2 09 05  18 1C C0 00  20 20 20 20  FF 00 B6 B6
  Offset 50:  07 07 17 F1  0C 03 00 00  A8 A8 A8 A8  00 00 00 00
  Offset 60:  00 02 00 00  00 00 00 00  00 02 00 00  00 00 00 00
  Offset 70:  02 01 00 00  00 00 00 00  02 01 00 00  00 00 00 00
  Offset 80:  F8 2E 34 02  00 00 00 00  00 00 00 00  00 00 00 00
  Offset D0:  06 00 71 05  06 11 71 05  00 00 00 00  00 00 00 00
B00 D11 F05:  VIA AC'97 Enhanced Audio Controller
  Offset 00:  06 11 59 30  01 00 10 02  50 00 01 04  00 00 00 00
  Offset 10:  01 E0 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  06 11 61 41
  Offset 30:  00 00 00 00  C0 00 00 00  00 00 00 00  0C 03 00 00
  Offset 40:  01 CC 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 80:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset C0:  01 00 02 06  00 00 00 00  00 00 00 00  00 00 00 00
  Offset D0:  01 00 02 06  00 00 00 00  00 00 00 00  00 00 00 00
B00 D12 F00:  VIA VT6102 Rhine II Fast Ethernet Adapter
  Offset 00:  06 11 65 30  07 00 10 02  74 00 00 02  08 20 00 00
  Offset 10:  01 E8 00 00  00 10 00 E8  00 00 00 00  00 00 00 00
  Offset 20:  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 30:  00 00 00 00  40 00 00 00  00 00 00 00  0B 01 03 08
  Offset 40:  01 00 02 FE  00 00 00 00  00 00 00 00  00 00 00 00
  Offset 50:  00 00 80 04  00 00 00 00  00 00 00 00  00 00 00 02
B01 D00 F00:  nVIDIA RIVA TNT2 M64 Video Adapter
  Offset 00:  DE 10 2D 00  27 00 B0 02  15 00 00 03  00 F8 00 00
  Offset 10:  00 00 00 E6  08 00 00 E4  00 00 00 00  00 00 00 00
  Offset 30:  00 00 00 00  60 00 00 00  00 00 00 00  0B 01 05 01
  Offset 40:  00 00 00 00  02 00 20 00  07 00 00 1F  04 01 00 1F
  Offset 50:  01 00 00 00  01 00 00 00  CE D6 23 00  0F 00 00 00
  Offset 60:  01 44 01 00  00 00 00 00  00 00 00 00  00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000  U.Z.K7400.L.w.VIDEO ......U...IBM VGA Compatible......&.06/27/01
C000:0040  ..............................PMIDX.[............[.NV....(.....
C000:0080  ........m.........P...q(a.........b.........?>76...^............
C000:00C0  ........................................PCIR..-.........Z.......
C000:0100  NVIDIA TNT2 Model 64 VGA BIOS...................................
C000:0140  .................Version 3.05.00.10B25 ...Copyright (C) 1996-200
C000:0180  0 NVidia Corp...........e............n............z........z....
C000:01C0  ....z........z........z........z........y..h..0y..h..0z........y
C000:0200  ..h...z........z.....%. z.....b.Az........z.....W..cn...........
C000:0240  .n.........b.Az..h.....z........z........n..h.........x..8..x...
C000:0280  .?x..(..x..3..x..!..x..+..x..,..qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
C000:02C0  qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
C000:0300  qqqqqq.]....xi....`m....Hq.....}................p.....X.........
C000:0340  ..P."."...%.%.VESA................Riva TNT......................
C000:0380  .....Chip Rev B1.....................................@.@. . .h.h
C000:03C0  .j.l...9.....`2...f..Pf...f..Wf.Xf.......f...f..)....t....f.a.`.
------------------------------------------------------------------------------------------------------------------------[/code]
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
yes, but if you are matching new RAM with existing RAM it will only run the top speed of your existing RAM, so, it would run at PC2100 (266Mhz), but you could buy PC3200 (400Mhz) but it will only run at 266Mhz because of your existing RAM
