does anyone have this case( http://www.newegg.com/Product/Product.asp?Item=N82E16811119077 ) if so plese tell me how to get this plastic mesh off so i can put a cd drive in. i hope i wont have to take the front panel off or somethign.
PC Components, Gaming Gear and Custom Solutions | Cooler Master
That’s the manual. There might be some tabs that you have to press in to push out the cover…
thanks big b aparently i had to rip off teh front of the cover and unscrew it mesh. It was jsut locked in by some snaps it jsut took a little force to rip it off.
hi, i use to have this case as well, it was excellent for cooling. But after a while i was bored of it and wondered how i could mod it. So from the original look i go to the stage shown on the pic. It took me ages to figure out how to remove the mesh grills though but after some brutal effort, finally figured it
