i got this error message while playing in coall of duty 1.5 in GameArena servers. i get kicked by punkbuster because of this. please help, because i get kicked i can’t play scrims! btw, it only happens in these servers.
[QUOTE=roy92]
yo amigo it appears that the server thinks your cheating by disabling the fog (i assume)
in any case it doesnt like that your r_nv_fog_dist is enabled. in console if you type /r_nv_fog_dist 0 or go into your graphics options and set Nvidia Distance Fog to no
i can’t find the fog options and the command doesn’t work. do u know where it is?
following newpaws I have found simillar answer on the net for this problem
Load up the game
In the menu system bring down the console using the ` key
type: /seta r_nv_fog_dist 0
or seta r_nv_fog_dist “0”
press enter
Now try reconnecting, hopefully this will have corrected the issue. You may need to restart COD after this change!
i found out how to do it. i went to options->graphics->nvidia distance fog. i then disabled it then went to play in GA server. i then got kicked for not doing anything after 15 or so minutes. Thanks for your help guys.
