how can i return CPU-FAN reverse (left or right ) ?
[I][SIZE=3][SIZE=5]how can i reverse cpufan or powersplay fan left or right in bios or with a code [/SIZE]
[SIZE=5]anybody can help me ?[/SIZE][/SIZE][/I]
[B]you can think of as a thesis.
Professor aydin says; if you detach to fan for cleaning.you don’t use computer.the computer uses you :smiley:
to this end.
instead of demounting the cpu fan when it’s get dirty i can reverse the fan.
Professor said to you can do this with a code.
[/B]
Even If you could reverse the fan, It Would NOT clean All of it..And this is not a good Idea,those fans are met to run only one way…It would probably burn them out..
