How do you build your own computer case?
i’m gonna post my case pics and then u guys can give me some suggetions on what i can do to make it look better. the link below is my computer case.http://www.itsbits.com.au/frames.php
Your link only goes to the main page of the website.
http://www.itsbits.com.au/inc.php?inc=info&uid=1071&return=%2Finc.php%3Finc%3Dproducts%26mcatid%3D21
hope this one’s better
The link works. Honestly, that case is kinda small, but it can work.
Something like this is a little bigger, and might offer more for you to work with.
I’ve looked at the Mambo before, I’m not very creative and i thought i couldn’t do anything with it. Suggestions would help.
btw, i dont realy like the curve in the front of the case coz i want to make a hole and put a fan in it and i think it wouldn’t look that good.
bout this case??
http://www.pccasegear.com/prod3157.htm
why you just want to make a hole in the front? You can make it on either side or on the top…I mean any where but why front? because front is the main part which has to be attractive…according to me…its the first impression and first impression is the last impression~!
obviously bro, uve got no taste.
If anyones still interested, im building a case for certain, dimensions W=15 x H22 x D 25, made out of aluminium, 6 120mm fans 8 harddrive bays 4 5.25 bays will post the progress ASAP
ok, turns out the aluminium is gonna cost me 800 dollars, but a friend is giving it for free.
Blimey generous friend you have there.
Good luck with the build!
