Without taking apart the case and sticking your finger on the chip/card, what’s the easiest way of checking the temp of the PC?
I have three case fans, one on the top, and two somewhere else. It’s pretty noisy, but keeps things cool when idle, but come game time, there is warmth from the back of the case (obviously) - so roughly how hot should this air be? I can put my hand over the case and not have to move it, just sorta warming.
If your system doesn’t crash or lock up during intensive stuff (gaming, for example), it’s not too hot. You should have the hot air going out of the system.
What kind of temps are you getting? If you don’t know, you can use Asus PC Probe (which I really dislike), or motherboard monitor or speedfan. (hit up google)
i replaced my stock heatsink for a coolermaster 3200+ which i have on an older machine.. cost me like £6.00 knocked the temperature down by about 10C to 46C non-loaded.. which is still pretty poor..
i’ve ordered a slk-900a and a 5500rpm fan.. (i’m not to fussed about noise) when im using my pc im usually gaming with decent headphones so i can’t hear it. my pc is running at about 45db
