how to edit ECC code
Hi , can I change the ECC code for a block of a file stored on a flash drive by any means ? of a file stored on a HDD (though I don’t think there would be a difference between the two)
Maybe , through some hardware interrupts or anything like that?
Also if possible I need the solution to be in C/C++.
If my question in unclear this is the ECC code I am referring to Eureka Technology - NAND Flash Controller IP core FAQ
