How to setup new LG LED monitor (51cm) ?
Hi
The contents in the box are dvi cable, vga cable, power adapter, power cable.
I wish to know how to set up the new monitor to CPU?.
I am ok with connecting the power cable and power adapter. Whether i need to connect dvi cable(white) or vga cable(blue) to CPU?
Looking for some help
thanks
maya
What kind on monitor is this Please ??? And what is it hooking up to ??
The monitor is LG LED Monitor.
I want to connect dvi or vga cable from the cpu to monitor.
I wish to know how to do this ?. Which cable is right one??
thanks
Ok, first of all CPU is a Processor, Now What make and model is your Computer ? What kind of graphics card does it have ? Is your video onboard or added ? What does your computer have on the back of it, VGA or DVI or Both ???
