Try this:
Right-click on your desktop, and click on Properties. Click on the tab Appearance, and then on the button Effects. Check the option “Use the following method to smooth edges of screen fonts”, and select Cleartype at that option. Now click on OK at both screens.
Unfortunately your SS looks like any other start button. Is it just the start button that looks like crap, or is it everything? I unforunately cannot tell from the SS. If it is everything that looks off, are you running an LCD? Is it at its native display resolution?
If it is just the start bar, get a new theme. Get the UXmultipatcher and use a custom XP theme like I do.
i did it … and it seems more clear from befor but the font in websites and
in the notepad changed a bit its stay unclear enough its horrible i think its temporary solution and thanks for u
thanks for your reply
and no it isnt … it is not like other start buttons … and also the fonts and the games seems unclear
and about the LCD no i have CRT (Desktop Monitor)
and i think its not native resolution becouse when i’ve just formtted every thing seems good and clear but then after 2 days its apear like u see
