Hi all,
Just wondering if you can help me here. I have a USB to SATA/IDE hard drive adapter and I have been using it to try and copy data from an IBM Deskstar 80gb ide hard disk which I had in a previous desktop pc under Win xp. When I plug in the usb adapter to my Dell Inspiron 6400 laptop it picks it up. Also in device manager under disk drives it picks it up as ‘Disk Drive’ with the following properties;
Disk: Disk1
Type: Dynamic
Status: Foreign
Partition Type: Master Boot Record (MBR)
Capacity: 0
Unallocated Space: 0
Reserved Space: 0
Windows explorer doesnt pick it up or assign a drive letter. I had a look in Computer Management>Disk Management and rescanned for disk but it could only pick it up as a ‘Disk 1, Dynamic, Foreign’ with an exclamation mark, i right clicked on it and chose ‘import foreign disk’ but i get the following windows error; ‘The operation did not complete. Click the System Event Log for more info on the error’.
I also set the jumpering on the disk to device 1 slave and also with the jumpering cleared and still no luck. Any input or ideas is greatly appreciated.
Thanks a million!
