I'm a stupid newbie, help me!
Something is wrong with my USB drive and I think I have to tighten it… I’m trying to get the front part of the casing off but I can’t find any screws that hold it in place, I’ve got the two sides off.. any advice at all would be appreciated!
[QUOTE=Stew]
What kind of case do you have, this would much help us with a visual as how the case looks the original face plate should have a screw from inside the case with a hook on it to hold it in :stuck_out_tongue:
[QUOTE=Sdawg1010]
never mind, turns out I can just plug the printer into the back… I haven’t used my printer in 3 months cause I thought I couldn’t use it lol… goddammit I am dumb. Thanks for the reply though
