Im trying to install a card reader in a 5.25" slot,
The card reader seems to have three cables (other than the molex) coming off it -
A nine connector cable (sound fairly obviously) - is this worth connecting up as i will only need it infrequently and probably do without.
A USB Male connector (also included is an adaptor of female USB to x connectors) - I take it this can connect to either an internal USB port or to the USB 2.0 Header USB45,Blue
The third connector i assume is the firewire or IEEE1394 port, to what does this connect to? Looking at the Mobo the only likely places are the USB 2.0 Header USB67,Blue or the System Panel Header.
Any Advice on this before i wreck everything would be a great help
One Firewire cable comes out of the back of the drive and there is only one firewire port on the front of the drive, i would guess that there is nothing but wire between the two (if you dont plug the firewire cable coming out of the back of the box, then all you will loose it the firewire port on the front).
The USB cable coming out of the back of the box is most likely linked up to everything on the front (apart from the audio jacks and firewire), if possible plug this into a USB port INSIDE the computer (PCI USB expansion cards frequently have these)… if you cant do this you will have to connect it up to the pin header (“USB45,blue”) on your motherboard.
Im guessing the “nine connector cable” is for your audio? i have never heard it referred to as such before though… (and google / google images / wikipedia gave me nothing).
Depends on your mobo, but like i was saying, i suspect that the only functionality you will lose if you don’t plug it in is the firewire connector on the front.
if your mobo doesnt have the pin headers for firewire, and you want / need firewire, then you will have to buy expansion card.
