insulation tape yes or no?
i have a question, it might sound stupid to some 1 who has used this b4 but what the hell. i have just bought a case now when ever previously i have bought a case to build a system then i always found no problem in fitting the board etc in. i have now bought a case with raised holes regarding screw holes for the board. the case plastic spacers did not come with the case for some reason…can i use insulation tape to stop the board from touching the case and causing me problems . please help as i need the system soon as have customer waiting lol he is getting alittle annoyed to say the least with waiting lol
Well, you can, but if you don’t have the proper mounting studs, I’d expect to have a helluva time trying to mount the motherboard in the case. Additionally, I don’t know how it’d hold up in the long run.
so dya think that i should be ok with just the pink plastic spacers?
