Is it blown??
Now then, after coming back from a trip to London I discover that my PC doesn’t work.
I try a different plug in the back suspecting it might be a fuse and then as you can imagine to my joy the fireworks start. A beautifull white flash follows coming from the PSU.
Just for a laugh I try changing the fuse and test it. No suprises, it doesn’t work.
Next I open the PSU and see a popped fuse solderd to the PSU board. The shop I take it to switches the fuse making sure they’ve put the correct size in and I take it home carefully installing it. I come to switching it on and then… Nothing.
So, my PSU is probably goosed. But what other things do you think are going to be goosed? Is it time to take it to a repair shop and get the old volt/amp/resistance meter out?
Help!
[QUOTE=snakeeyes]
[/quote]
not suprising, fuses usually blow for a reason, if you can, try to find what that reason is, or try replacing the PSU
you may be lucky, try replacing the PSU and see if your system lives
Cheers donks.
No doubt I’ll be back like a rash if it doesn’t work but thanks in the meantime. I’ll give it a do. Any more suggestions though keep em’ coming.
Alex
Difficult to say really. Usually the motherboard becomes a victim of a PSU failure. Sometimes the processor and PCI/AGP cards die as well
Yeah, thats what I was thinking too. Well, something along those lines anyway.
It just keeps getting better and better doesn’t it? :wink:
Q: Should I try just powering a different PSU up on it’s own to see if the juice is going through ok? Then add bits on like m-board?
Q: How will I know if the m-board and such is blown? Heavenly message or maybe it’s take it to the computer docs time.
[QUOTE=snakeeyes]
[/quote]
yeah
it’ s just trial and error, everything else could be fine, or the PSU could have fried everything (CPU, mobo, RAM grafx card) just try them to see if they work[ot]you may be v lucky, and only the PSU could be dead[/ot]
As you know that your PC’s PSU is already dead n u r left with no other choice so instead of trying any generic PSU from any other machine you should jst go and buy a new one. To get more information on which PSU to buy or wat to look when buy a new PSU then go [link=http://www.hardwareforums.com/power-supply-sticky-5218/]here[/link].
First thing you will notice on your Mobo is a light on it. Then you need 3 things to start your PC. CPU, RAM and HDD… Jst add these things and see the reactions of your computer. If it boots up then start adding things, Good luck :wink:
[QUOTE=Karan]
[/quote]
if his mobo has a light on it, my mobo doesn’t have one
my system also requires a grafx card, i though most systems also required grafx
You dont actually need a HDD to start up your pc :), obviously to do anything you need a HDD unless your using Live Cd’s.
true, but generally you only use a Live CD to install Linux or to help with diagnosing or fixing[ot]:stuck_out_tongue: [/ot]
Oh really… Neva knew bot dis ..:ohah:
hmm… true again!
I’d replace the PSU for starters. Smoke coming from a power supply is a wonderful indicator that the unit is shot. If you don’t happen to have a surge protector in use, it’d be a good time to purchase one. APC or Belkin make some good units.
yea i would go buy a new psu tomoz or order one, boxing day sales will be on…
chances are your motherboard may have been affected also so bare in mind you may have to replace that
Cheers J-man, Willz, Big B, Karan, donks and mega. Sorted now. It’s alive again and all is well in the world.
