Is this motherboard right for me
Hello friends,
I am going to buy a new motherboard
MSI K9A2 Platinum AMD 790FX Motherboard
i would like to know are there any better boards within this price range i am in web graphic design 3d and video editing
Hello,
In my personal opinion it is great motherboard for someone in gaming because you have quad GPU. But if you are in 3d and video editing you need strong graphic design card like nVidia, regarding motherboard I would recommend something under i7 processors because they can handle many threats. some think like this ASUS P6T
You want the top; look no additional, because you are stare at it. This is absolutely a top choice as far as Core 2 Duo motherboards go. The BIOS is easy to flicker and update, there are plenty of USB ports, along with Fire wire. The layout of the board is perfect, easy to reach IDE port and FDD port. The stock cooling on the Northbridge and Southbridge is exceptional. It comes operational with 3 PCI ports and one PCI-E 1x slot. The only complaint is the amount of tweaking around 500 FSB. Some boards take time to find their sweet spot, this board integrated. Though, that is the only downside of an almost unblemished motherboard.
ok friends,
since that motherboard is not available i was recommended MSI 790FX-GD70 need your views on that too
@daz i am not a very big asus fan so going for msi
thanks
i also want to know can anyone guide me to anice tutorial of how to mount motherboards with pictures since i will be trying to install motherboard myself for the first time including attaching processor ram fans etc for atx case
from who I can see It Is really good motherboard. I would go with this one, and youare wright MSI Is better then ASUS. I know that from my own experience. I will try to do together some photos for you with motherboard Installation.
thanks daz that would be great i wud also want to know how to connect the psu with the motherboard and other components:D
many thanks again cheers
Thanks for the good informative post.keep sharing.
@ daz i got this tutorial on assembling pc great tutorial :slight_smile:
Nice, I see that after all I din’t have to do photos of my lovely PC. and I so wanted to do it :slight_smile: good luck with your PC. I always enjoy potting new PC together
I wud definitely like to see some pics of ur pc if u dont mind showing to us:D
Hear it is.
That’s the only way that I could pot some photos fast:)
I hope that it will work, It is nor very new I got it 2 years ago, but I love it.
Thank you for interest, It you want specks of my PC let me know.
Please go ahead
MSI K9A2 Platinum AMD’s 790FX motherboard, the design requirements should be no problem
I run right now.
Windows Vista 64 Ultimate
Intel Core 2 Quad 2.83 GHz
ASUS Rampage Formula
Asus Geforce GTX 280
Hitachi 2TB HDD,
I don’t remember memory right now (but definably it is DDR 3 1333)
:slight_smile:
Now it is actually windows 7 64 bit Ultimate.
^^ what case u use?
