Is itunes able to connect to anyhting other than the ipod line? I have an rca lyra and i was wondering if their are any drivers that can be installed to get it to recognize it.
hmmm, not sure if you can, I’ll do a bit of search and get back to you.
[QUOTE=Runner7775]
If it was me, I’d just use Amarok, as it’s way better than iTunes anyway. Of course, I’m pretty sure it’s for Linux or Unix systems only. Even so, you should be able to move files to and from the device just like a normal USB hard drive, right?
