I’m running a:
P4 2.4Ghz / 1GB (2x512MB) / MSI Neo2 PE
The motherboard was second hand and i picked it up for £15 due to problems with the onboard sound..
anyway i installed a Soundblaster Live Audio card which i know works, it’s all properly installed with the latest drivers..
For some reason every month or two the sound will suddenly stop working, ingames, playing music, through media players, through any of the optical drives Head Phone ports..
Everything just goes.. Windows is setup to use the Soundblaster card by default, and i have disabled the onboard audio via device manager.
The strange thing is.. there are no errors at all, when i open a music file it seems to be playing, but i cant hear it.. and all the volume settings are fine!
When ever i get this problem, all i do to fix it is use System Restore to set the computer back to 1-3 days before the problem started and it works perfectly, and then the problem wont happen for another month or so..
all very annoying..
any ideas?
