Hey all i recently re built my pc due to motherboard failure. I currently have the ASROCK P45TS Motherboard. Alls working fine apart from a few issues. I overclocked the cpu Q6600 GO kentfield to 3ghz, fsb 1333mhz, ran prime 95 and sisoft sandra its all good, runs windows perfect, games, no crashes etc.
Operating system: windows xp 32bit sp3
Issue 1: when i first turn on my pc from cold it boots into windows and there is no network connections just blank, it doesn’t pick up my Realtek NIC even in device manager. But when i restart the pc it appears in network connections and device manager and works perfect wtf?
I’ve tried re-installing the lan drivers still the same.
could this be a bios fault? or driver fault? even an overclock fault?
Issue 2: I’ve installed the audio drivers for my Realtek HD Audio, everytime i boot windows it comes up sayin I havn’t installed drivers for microsoft uaa bus drivers for hd audio. the audio works fine by the way. just wanna try and stop it from coming up everytime i boot. any help would be much apreciated. thanks bobby
hi thanks for your reply. yea i think im gonna update the bios see if that fix’s my lan problem.
the hd audio doesn’t appear in device manager, it just pops up everytime i boot, theres no yellow exclamation marks in device manager what so ever. yea all chipset drivers are installed INF drivers.
oh yea another thing i forgot to mention, when i re built my pc with the new Asrock p45ts motherboard, i didn’t format the hard drive, so it had the old motherboards chipset drivers on the hard drive, i just uninstalled them and installed the asrock p45ts mobo drivers. could this also effect the lan problem possibly? thanks
Also today when i booted up from cold. the realtek Nic was there i didnt have to restart the pc.
You can use the Windows System Preparation Tool (download from MS) to strip out the old driver entries from the registry before booting on a new mobo. It doesn’t always work (what do you expect from Microsoft?), but that’s the official way to migrate to a new motherboard. Still, if it was me, I’d backup my data under the assumption that Windows will bluescreen on boot – and then be pleasantly surprised if it actually works as advertised. Also, you’ll probably have to deal with reactivating Windows once the motherboard changes, so don’t be surprised by that either.
Hi, all thought I would let you know what the problem was, It just need a bios update because it wasn’t detecting the LAN controller from cold turn on. Now all fine, so if anyone else comes across this problem, theres ya answer
