[Laptop] Network controller problem
I had a problem with my wireless connection, so tried to install new drivers, but it couldn’t find one, then i unstalled the device, restarted my pc, install new hardware, check for drivers on internet, but it couldn’t find one.
Ive tried to download the intell proset…, but on the istallation it says"couldnt find device"
sow i can’t istall my network controler, now i can’t go one wireless networks again, what should i do?
Have you checked to see if there is a wireless switch on the laptop? Mine has one on the front which turns off the wireless adapter.
no, it hasen’t. it looks like the laptop event hasen’t a wireless thing, becaus,he can’t find the device, sow i think i schould bring him to a shop to look at it.
Yes it sounds like a hardware fault, so a shop would probably be your best bet, although I imagine it won’t be cheap!
i hope it isn’t expesif, becaus its actually my mothers laptop, and i f*cked it up sow
probarly i have to pay lolz
but thx for your help
