I am trying to install my wifi card.
Ive already successfully done this in Xubuntu but have now decided to use Debian (cos Debian with gnome is quicker than xubuntu!)
I need to install ndiswrapper common and utils. I installed them using the synaptic installer because they were in the list but I then because linux cant find the ndiswarpper module I cant progress any further with the install. (its the command modprobe ndiswrapper which returns that ndiswrapper module isnt found)
I dont know what ndiswrapper is but it does seem to have “installed” the windows driver I need to get my wifi card working.
So I decided to do it the way I know works and install them using two .deb packages.
Ndiswrapper utils fails install because “error: dependency is not satifiable: libc6”
Libc6 is installed, and it is the latest version.
Hopefully someone here will be able to say " open ***, click on *** and press the red button" and all will work for me!
I really dont want to use ubuntu now, debian is what it is based on and its quicker. Original is best imo!
