Lights hook up?
So I got my computer back from the “shop” months back and I noticed my lights weren’t working anymore after getting a new power supply and graphics card in it. I haven’t bothered with it until now when I’m just now turning it back on after about 3-4 months. -Family issues wouldn’t let me get on my computer-.
There are two “prongs” in this that connect to my lighting in the front. I can’t figure out where it goes. :confused: If you need a picture of my comp better or the cord better; I’ll get you one. My camera is kind of sucky.
Any help please?
What case do you have ? Make and model would help..
It’s custom built so I really don’t know. :confused: I’m not really good at this stuff so please bare with me.
Is there anyway I could find out the case model/make?
Can you give me a picture of it ?
Sure. Here you go:
Will give better picture if needed.
Nice case… The connection is a molex connection..They are used for lights and for case fans or side door fans..Which lights are not working ?
just plug it into your power supple connection..
Well the lights in the front of the case. I can get a picture if you need one. The very front of the case. It’s a UV light looking thing and it is blue.
Really think the case is nice? The case was given to me for free and I didn’t think anyone would actually like it.
I can’t find anywhere to actually plug it in. :confused:
Yea ! give me a front shot to see what it is.. That connection should just plug in to an empty power supply connection..
Okay give me like 5 minutes please.
Here you go.
It looks like this here…Silver Aluminum X-Pider ATXA2XPW Mid-tower ATX P4 Computer Case 420W CWT PSU-Best Computer Online Store Houston Buy Discount Prices Texas-Directron.com
Pretty close. That case right there is really nice! Anyway. I can’t find any connector for my lights at all. :confused: Want a picture of the wires and stuff?
Thanks for all your help so far.
Is there any unused power connections from the power supply ? If not ,then that is why they left it unhooked.. You might have to make something up,or you can get a adapter.
Do you have the Old power supply ?
Yes sir and no sir.
There are two unused connections. One black slit type one and another that’s white and in a block way. I can get a picture of it if needed.
No sir I do not have the old supply.
Well then you will need something like this..
Free USPS Shipping Y-Cable IDE, “Y”-Shaped Power Supply Adapter Cable for IDE Drives-Best Computer Online Store Houston Buy Discount Prices Texas-Directron.com
Alright thank you for your help. Any extra details/questions you want to throw in?
If you had the old power supply, then you could make one up..
NO problem for the help, that is why we are here.. take care now and welcome to are forum..
