Limited or No Connectivity
Hey all,
Thanks for the help last time!!!
This morning I woke up, booted the old tower and got this message:
“Limited or No Connectivity”
I have done a few searches on the webiste here, tried that Winsock fix but nothing! I have reinstalled my drivers for my network card and still nothing. Kinda getting me ticked off! I’ve tried evrything I know, what would you suggest?
Start > Run > Type ‘cmd’
Then in the command prompt type:
ipconfig /release
then
ipconfig /renew
Adding to the Megamaced quotes…
There is another way of doing the same thing…Right Click on the connection icon and select Repair.
If the previous solutions doesnt work then look at the wire if its properly connected to your Lan Card and to the phone line. If all else failed then call your customer support centre…
Thanks guys!
It ended up being an issue with my ISP!
