I`m newbie to these things. pleases don’t flame me.
I just bought a liteon dvd rom sohd-167t.the problem is it cant read any DVD 9 movies. I had tried 3 differents dvd 9 movie but still the same. But it can play the single layer dvd movie. I had check with the neroinfo tool. It said can support dvd dual layer even the one whos sellin me this dvd rom had tried at his own city, can play the dvd 9 without any problem, he said. Any ideas wad`s going on??
It said windows cannot read from this disk.the disk might be corrupted, or it could be using a format that is not compatible with windows. why??
The only conclusion i can come to is a problem with the drive itself, but you could try configuring the drive as a Master(assuming its a slave), or a Slave(assuming its a Master), catch my drift?
[QUOTE=pelvis_3]
i had tried that method b4 yet still the same
does it mean my drive can`t support dvd 9??the neroinfo tool give me the wrong report??
longshot but download a trial version of AnyDVD and start that before your dvd player and check back!
Have you tried the drive in a different computer?
ok…i used power dvd 5 and it said a disc with an unsupported format.dvd 9 use wad kind of format??i had download the newest codec package and install it,damn it,same problem. >.<
i had tried all method tat u guys said,still doesnt work.i tried it at my friend computer and still the error said the file is unsupported.these r “P” dvd 9 tat i bought from town.but the seller said he doesnt have any problem with it when playin the “P” or original dvd 9.its brand new,so i think its not the drive problem??
