oh yes, they are called expansion slot coolers or slot exaust but i would guess they would interupt the proper air flow on the 580’s because the 580 intakes air from the fan on the side of the card then exaust it out of the grill on the back of the card. those slot coolers would pull hot air from the rest of the computer down near the video cards so they will be intaking hotter air than ussual.
The only other thing I might suggest is adding a case fan if you have a spot on the side to blow on the card(s). Don’t know if your case does, but if so, a case fan would be cheaper than the VGA coolers. A second thing might be tidying up your cables so any intake from the front of the case isn’t blocked. Zip-ties are really cheap and can be had at auto supply stores or any place with an electrical section (Lowes, Home Depot, Menards) as well as places like Wal-Mart, Target, etc.
