Hello! First time poster here! I am looking for some help with my rig.
Recently (within 6 months) I replaced my CPU and GPU after one, or both burnt up. I replaced cpu first and had no luck than gpu and all was well (although my CPU looked like it got hot!)
My motherboard idles at 78C, my gpu at 33C and my ram seems to always have at least 45% load (even at idle.)
My specs via direct x is located here : http://pastebin.com/hqpWNZTb
My log via HWmonitor can be found here : http://pastebin.com/x5CPbTLX
Is it a power problem? Maybe even a faulty motherboard( I have had it for a few years now.)
I should also note that I have a big I think 45mm? Fan in the back , 2 smaller in the front and one small on top of my case. I am not to sure which ones should be pointing in/out. I also notice my big fan may be dieing/ isn’t cycling at 100% speed/ seems to struggle sometimes. I have not had any power downs but my system does seem to lag a big. Recently I have been playing Minecraft and Eve: Online (dual boxxing) and have not had the system restart but the temps do run high so I try to keep my play time limited, which stinks because EVE is a subscription based mmo.
Thank you in advance for any help!
