I need to fix a problem of my laptop cpu fan by using the lubrication to lubricate the fan.
I do not know what’s kind of lubrication I can use the lubricate the laptop cpu fan.
Any suggest? or where I can find them in the local store etc, home depot, best buy or computer USA?
[QUOTE=robine]
You can use light machine oil, of the type used on sewing machines. In the US, it’s available at Radio Shack, among other places.
-AT
