Hello all, I am eceiveing a Machine_check_exception Stop:0x0000009c BSOD error.
I’m having a problem with my dvd burner Sony DRU 500A (its quite a few years old, but I only burn dvds a few times a year). What happens is that the burner is able to burn blank discs, but when I insert a dvd or dvd-rw with anything on it, my computer freezes and i get the blue screen of death. I get “Machine_check_exception… Stop: 0x0000009c” (If the disc is blank, its business as usual.) The blue screen error i get indicates a hardware problem. So I just bought a new Samsung burner from newegg.com, and it turns out i’m getting the same issue with the new drive, that my burner can’t read any dvds. Its weird since my regualr dvd drive is able to read the discs with no problem. So i put the old burner back in and i swapped them from master to slave. same problem. I then switched IDE cables, same problem. I even switched the ide sockets on the motherboard and it didnt work. I don’t know what to do next. I was thinking of re-formatting my computer and maybe that will fix it? Could it be an operating system issue (im running XP), and maybe something got screwed up along the way?? I have no idea. I’m hoping its not my motherboard, since any AMD socket 754 chipset motherboard is now hard to come-by. Do you have any idea of what might be the issue? I’m lost!!!
Im running:
AMD Athlon 64 3000+ Newcastle 2.0GHz 512KB L2 Cache Socket 754 Single-Core Processor
ABIT NF8-V2 754 NVIDIA nForce3 250 ATX AMD Motherboard
2 gigs of DDR400 RAM
Thanks to all
