I’d like to run playstation games on my MacBook. I downloaded PCSX, but it needs CDs, which I don’t have. Then I found FlareStorm 2, which seems to be able to read ISOs, but when I try to add an image, it just wouldn’t let men - in the insert image dialouge box it doesn’t allow me to select the iso image (or bin, or cue)… any ideas?
I’ve always had great success with ePSXe for Linux. Unfortunately, there is no MacOS X Version.
But, you might try the FreeBSD port of ePSXe FreeBSDPorts.info FreeBSD Ports - emulators ports, linux-ePSXe port (MacOSX is based on FreeBSD). If you can’t manage to get that working, there’s always the Windows binary; you can try running it in Parallels or whatever, or barring that, maybe in WINE: Wine AppDB - ePSXe 1.6.0
