Macs and PC's
Whats the difference/s between MAC’s and PC’s?
Mac isn’t x86 for one, and it’s typically been very proprietary in the past. It’s enough that you just can’t drop in the same card from you’re PC in a Mac. Mac’s are getting more PC-ish all the time, but the architecture is different mostly.
Thanx a lot m8, thats helped me a lot.
May not be totally correct, but I’m certain the arcitecture is different.
YEP!!
You were correct, I asked somebody in a chat room on aol about it.
THANX
