Major Problem with PC
Hi, i’ve had my computer for around 4 years now. When i got it everything ran fine and i spent many happy hours gaming. I have had no hardware changes since then and i have all the lastest drivers with all of my components.
Now, my computer refuses to play any games that it can easily handle, even freezes with some big programs such as 3ds max or even itunes.
It basically freezes in random places making the game impossible to play. I posted a video of me playing Call of Duty 2 multiplayer.
Its running on the lowest settings possible, but it should run even on max settings.
I don’t know what it can possibly be. I’ve searched around for someone with the some problem but i’ve never found anything. If any one has encountered this problem before or has any ideas on how i could fix it i would be hugely grateful. Thank you very much
My Specs:
Os: Xp Sp2
Cpu: AMD Athlon 64 3200+
Gpu: Nvidea GeForce 6800 GT
Motherboard: Asus k8n
[code]------------------
System Information
Time of this report: 7/4/2008, 22:40:52
Machine name: COM-40A3447F235
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_qfe.070227-2300)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTek Computer Inc.
System Model: K8N
BIOS: BIOS Date: 09/06/05 20:25:26 Ver: 08.00.09
Processor: AMD Athlon™ 64 Processor 3200+, MMX, 3DNow, ~2.2GHz
Memory: 1024MB RAM
Page File: 634MB used, 1825MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
    Card name: NVIDIA GeForce 6800 GT
 Manufacturer: NVIDIA
    Chip type: GeForce 6800 GT
     DAC type: Integrated RAMDAC
   Device Key: Enum\PCI\VEN_10DE&DEV_0045&SUBSYS_00000000&REV_A1
Display Memory: 256.0 MB
Current Mode: 1920 x 1200 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6921 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/5/2007 02:41:00, 5773568 bytes
WHQL Logo’d: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/5/2007 02:41:00, 7435392 bytes
Device Identifier: {D7B71E3E-4305-11CF-B978-0B2000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0045
SubSys ID: 0x00000000
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
        Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_10DE&DEV_00EA&SUBSYS_812A1043&REV_A1
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5865 (English)
WHQL Logo’d: n/a
Date and Size: 6/16/2005 17:24:24, 2324160 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX™ 2.0 Listen/Src: Yes, Yes
I3DL2™ Listen/Src: Yes, Yes
Sensaura™ ZoomFX™: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
    DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
 DLS Version: 1.00.0016.0002
Acceleration: n/a
       Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
              MPU-401, Hardware (Kernel Mode), Input, No DLS, External
              MPU-401, Hardware (Kernel Mode), Output, No DLS, External
              Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
              Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
              Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
              MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
              MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
    Registry: OK
DirectInput Devices
  Device Name: Mouse
     Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
  Device Name: Keyboard
     Attached: 1
Controller ID: n/a
FF Driver: n/a
  Device Name: Ideazon Zboard MM USB Human Interface Device
     Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1038, 0x0100
FF Driver: n/a
  Device Name: Media Tablet
     Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x172F, 0x0500
FF Driver: n/a
     Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
  • USB Root Hub
    | Vendor/Product ID: 0x10DE, 0x00E7
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 3/5/2006 15:40:32, 57984 bytes
    | Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
    ±+ Generic USB Hub
    | | Vendor/Product ID: 0x03EB, 0x3301
    | | Matching Device ID: usb\class_09
    | | Service: usbhub
    ±+ USB Human Interface Device
    | | Matching Device ID: usb\class_03
    | | Service: HidUsb
    | | Driver: hidclass.sys, 8/4/2004 00:08:20, 36224 bytes
    | | Driver: hidparse.sys, 8/4/2004 00:08:18, 24960 bytes
    | | Driver: hid.dll, 3/17/2006 11:22:14, 20992 bytes
    | | Driver: hidusb.sys, 8/17/2001 15:02:20, 9600 bytes
    | ±+ HID-compliant device
    | | | Matching Device ID: hid_device
    | ±+ HID-compliant consumer control device
    | | | Matching Device ID: hid_device_up:000c_u:0001
    | | | Driver: hidserv.dll, 8/4/2004 00:56:44, 21504 bytes
    | ±+ HID Keyboard Device
    | | | Matching Device ID: hid_device_system_keyboard
    | | | Service: kbdhid
    | | | Driver: kbdhid.sys, 8/3/2004 22:58:36, 14848 bytes
    | | | Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
    | ±+ HID-compliant mouse
    | | | Matching Device ID: hid_device_system_mouse
    | | | Service: mouhid
    | | | Driver: mouclass.sys, 3/17/2006 11:22:14, 23040 bytes
    | | | Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
Gameport Devices
  • PCI standard ISA bridge
    | Matching Device ID: pci\cc_0601
    | Service: isapnp
    | Driver: isapnp.sys, 8/23/2001 13:00:00, 35840 bytes
    ±+ Standard Game Port
    | | Matching Device ID: *pnpb02f
    | | Service: gameenum
    | | Driver: gameenum.sys, 8/4/2004 00:08:22, 10624 bytes
PS/2 Devices
  • HID Keyboard Device
    | Service: kbdhid
  • Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
  • Microsoft PS/2 Mouse
    | Matching Device ID: *pnp0f03
    | Service: i8042prt
    | Driver: i8042prt.sys, 8/3/2004 23:14:38, 52736 bytes
  • Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM6
DirectPlay8 Serial Service Provider: COM7
DirectPlay8 TCP/IP Service Provider: Wireless Network Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech™ 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
  Drive: C:
Free Space: 13.8 GB
Total Space: 60.0 GB
File System: NTFS
Model: ST3200822AS
  Drive: D:
Free Space: 76.4 GB
Total Space: 80.0 GB
File System: NTFS
Model: ST3200822AS
  Drive: E:
Free Space: 35.3 GB
Total Space: 50.8 GB
File System: NTFS
Model: ST3200822AS
  Drive: F:
  Model: SONY DVD RW DW-D22A
 Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:54, 49536 bytes
  Drive: G:
  Model: SONY CD-RW  CRX230ED
System Devices
 Name: Wireless-G PCI Adapter
Device ID: PCI\VEN_14E4&DEV_4320&SUBSYS_00131737&REV_03\4&22775069&0&4870
Driver: n/a
 Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_00ED&SUBSYS_00000000&REV_A2\3&267A616A&0&70
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2585 (English), 10/17/2005 18:36:26, 68224 bytes
 Name: Realtek AC'97 Audio
Device ID: PCI\VEN_10DE&DEV_00EA&SUBSYS_812A1043&REV_A1\3&267A616A&0&30
Driver: n/a
 Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_00E8&SUBSYS_813F1043&REV_A2\3&267A616A&0&12
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2783 (English), 1/16/2006 21:39:44, 27264 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2783 (English), 1/16/2006 21:39:44, 143104 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 01:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2846 (English), 3/5/2006 15:40:32, 57984 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:44, 7168 bytes
 Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_813F1043&REV_A1\3&267A616A&0&11
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 17024 bytes
Device ID: PCI\VEN_10DE&DEV_00E7&SUBSYS_813F1043&REV_A1\3&267A616A&0&10
 Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_00E5&SUBSYS_813F1043&REV_A2\3&267A616A&0&40
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2714 (English), 11/4/2005 20:45:54, 95616 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 3328 bytes
 Name: SM Bus Controller
Device ID: PCI\VEN_10DE&DEV_00E4&SUBSYS_813F1043&REV_A1\3&267A616A&0&09
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_00E3&SUBSYS_813F1043&REV_A2\3&267A616A&0&50
 Name: NVIDIA nForce3 250 AGP Host to PCI Bridge
Device ID: PCI\VEN_10DE&DEV_00E2&SUBSYS_00000000&REV_A2\3&267A616A&0&58
Driver: n/a
 Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_00E1&SUBSYS_00000000&REV_A1\3&267A616A&0&00
Driver: n/a
 Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_00E0&SUBSYS_00000000&REV_A2\3&267A616A&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 35840 bytes
 Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_00DF&SUBSYS_80A71043&REV_A2\3&267A616A&0&28
Driver: n/a
 Name: NVIDIA GeForce 6800 GT
Device ID: PCI\VEN_10DE&DEV_0045&SUBSYS_00000000&REV_A1\4&2E2DECCC&0&0058
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 7435392 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 5773568 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 385024 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 1089536 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 6901760 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 8523776 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11132 (English), 12/5/2007 02:41:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 6549504 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 3420160 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 1228800 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 3710976 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6921 (English), 12/5/2007 02:41:00, 2498560 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 12/5/2007 02:41:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 12/5/2007 02:41:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 12/5/2007 02:41:00, 35328 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 12/5/2007 02:41:00, 35328 bytes
 Name: Multimedia Controller
Device ID: PCI\VEN_109E&DEV_0878&SUBSYS_FF06107D&REV_11\4&22775069&0&3970
Driver: n/a
 Name: Multimedia Video Controller
Device ID: PCI\VEN_109E&DEV_036E&SUBSYS_FF06107D&REV_11\4&22775069&0&3870
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 3/17/2006 11:22:14 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 00:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 12/24/2007 17:44:44 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/22/2008 18:39:41 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/3/2008 20:27:00 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/3/2008 20:27:02 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/3/2008 20:27:02 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/3/2008 20:27:03 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/22/2008 18:39:42 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/3/2008 20:27:04 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/3/2008 20:27:04 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/3/2008 20:27:04 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/3/2008 20:27:05 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/3/2008 20:27:07 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/22/2008 18:39:42 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/22/2008 18:39:43 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/22/2008 18:39:43 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/22/2008 18:39:44 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/22/2008 18:39:40 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/22/2008 18:39:41 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/22/2008 18:39:39 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 13:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 11/17/1997 17:13:16 11776 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 22:47:18 211456 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 279040 bytes
qdvd.dll: 6.05.2600.2831 English Final Retail 2/19/2006 01:01:10 386048 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:26 733696 bytes
quartz.dll: 6.05.2600.3243 English Final Retail 10/29/2007 23:35:13 1287680 bytes
quartz.vxd: Final Retail 11/17/1997 17:13:16 5672 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 11/17/1997 17:13:16 10240 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 204288 bytes
ks.sys: 5.03.2600.2818 English Final Retail 12/28/2005 19:29:30 141056 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2790 English Final Retail 11/4/2005 19:55:10 48768 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 3/17/2006 11:22:14 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5504 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 10880 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2729 English Final Retail 7/29/2005 21:55:10 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,5.03.2600.2180
CC Decoder,0x00200000,2,1,5.03.2600.2180
WST Codec,0x00200000,1,1,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,
WMAPro over S/PDIF DMO,0x00600800,1,1,
WMA Voice Decoder DMO,0x00600800,1,1,
WMVideo Advanced Decoder DMO,0x00800001,1,1,
Mpeg4s Decoder DMO,0x00800001,1,1,
WMV Screen decoder DMO,0x00800001,1,1,
WMVideo Decoder DMO,0x00800001,1,1,
WMV9 Advanced Profile Decoder,0x00600800,1,1,
Mpeg43 Decoder DMO,0x00800001,1,1,
Mpeg4 Decoder DMO,0x00800001,1,1,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3243
Leadtek MPEG Muxer,0x00200000,2,1,WFMUXT.ax,3.05.0000.1231
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0015
Leadtek File Writer,0x00200000,1,0,WFDMP.ax,1.00.0000.0002
CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.ax,5.00.0000.0905
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0015
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3243
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3243
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3243
DV V/A Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
,0x00000000,0,0,
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
Ulead DVD Navigator,0x00000000,0,0,UleadDVDNavigator.ax,1.00.0002.0001
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3243
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Philips VBI Renderer,0x00200000,1,0,PhilipsVBI.ax,1.04.0000.0000
Ulead Video Deinterlace Filter,0x00200000,1,1,deinterlace.ax,1.00.0002.0005
Genesis VBI Sink,0x00800000,1,0,GdiVbi.ax,5.05.0000.0019
Leadtek Image Process Filter,0x00200000,1,1,WFVMSK.ax,1.00.0000.0004
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
DV V/A ACM Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Effect,0x00200000,1,1,claudfx.ax,5.00.0000.0901
Leadtek Audio Decoder,0x00601000,1,1,WFADC.ax,3.05.0000.1501
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0015
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0015
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0015
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0015
Nero Digital AVC Video Enc,0x00200000,1,2,
Creative Effects Filter,0x00200000,1,1,CTEffectsFilter.ax,1.00.0003.0000
Deinterlace Filter,0x00200000,1,1,Hcwdlace.ax,1.01.0000.0000
OrbUrlSource,0x00600000,0,0,OrbUrlSource.ax,1.2007.0522.1500
DV Video Source Filter,0x00400000,0,1,dvsf.ax,7.00.0000.0000
Nero QuickTime™ Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0015
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.3030
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3243
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0015
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.3243
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0015
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.0905
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
LeadTek Audio Encoder,0x00200000,2,0,WFAENC.ax,2.00.0000.5101
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0015
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2980
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0015
Leadtek MPEG Muxer,0x00200000,2,1,WFDMUX.ax,5.00.0000.1425
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0000
OrbNSVSource,0x00600000,0,0,OrbNSVSourceFilter.ax,2.2007.0216.1000
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0015
Color Converter,0x00200000,1,1,declrds.ax,9.00.0000.2980
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
LeadTek DTV Video Decoder,0x00400000,2,3,WFDVSD.ax,6.00.0000.1515
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3243
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0015
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2831
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3243
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3243
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0015
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.07.0000.0001
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0015
Ulead DVD Video decoder 2,0x00400000,2,2,ulDVDVideo.ax,2.00.0000.0033
LeadTek Dump Filter,0x00200000,1,0,WFPDump.ax,4.00.0000.5123
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0015
Dib Output,0x00200000,0,1,DibOutput.ax,8.00.0000.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Dib Receive,0x00200000,1,0,DibReceive.AX,8.00.0000.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0015
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
WinFast Data Transform filter,0x00200000,0,0,WFDT.ax,5.13.0001.2003
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2831
CyberLink Audio Decoder,0x00601000,1,1,CLAUD.ax,5.00.0000.0924
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,5.00.0000.0912
Hauppauge WinTV SnapShot,0x00200000,1,1,Hcwsnap.ax,1.12.21077.0000
CyberLink TimeStretch Filter,0x00200000,1,1,CLAuTS.ax,1.00.0000.0704
ULead Infinite Pin Tee,0x00200000,1,1,uinftee.ax,1.00.0000.0002
VFW Null Render Filter,0x00200000,1,0,P1120Vfw.dll,1.00.0001.6784
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2831
Leadtek Stream Handler,0x00200000,1,1,WFMVSB.ax,1.00.0000.0002
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0015
Cutlist File Source,0x00200000,0,1,qcut.dll,5.01.0051.0207
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3243
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
Leadtek Resampling Filter,0x00200000,2,2,WFTIME.ax,1.00.0000.0001
Ulead DVD Audio decoder 2,0x00200001,1,1,ulDVDAudio.ax,2.00.0000.0048
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0015
OrbRTSPSource,0x00600000,0,1,OrbRTSPSource.ax,2.2007.0216.1000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Leadtek File Source Filter,0x00400000,0,1,WFASYNC.ax,3.00.0000.0003
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2980
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0015
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0015
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2831
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0015
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1674
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Ulead MPEG Splitter,0x00400002,1,2,ulspmpeg.ax,1.00.0000.0104
Ulead MPEG Audio Decoder,0x00400000,1,1,ulDVDAudio.ax,2.00.0000.0048
Ulead MPEG Video Decoder,0x00400000,1,1,uldsmpeg.ax,1.00.0000.0079
Ulead MPEG Encoder,0x00200000,2,1,ulesmpeg.ax,1.00.0002.0047
Ulead MPEG Audio Encoder,0x00200000,1,1,uleampeg.ax,1.00.0000.0022
Ulead MPEG Muxer,0x00200000,5,1,ulmxmpeg.ax,1.00.0001.0133
Ulead LPCM Audio Encoder,0x00200000,1,1,ulpcmpeg.ax,1.00.0000.0007
ULead File Source (Async.),0x00400000,0,1,ulasync.ax,1.00.0000.0013
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
DScaler Audio Decoder,0x00800000,1,1,MpegAudio.dll,0.00.0006.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3243
Leadtek YUY2 DeInterlace,0x00200000,1,1,WFDIF.ax,3.00.0000.2207
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3243
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3243
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0015
Nero QuickTime™ Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0015
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0015
Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2980
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0015
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0015
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Moonlight Odio Dekoda,0x24111981,1,1,mlcom.ax,1.00.0000.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3243
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3243
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3243
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
OrbSourceFilter,0x00600000,0,0,OrbSourceFilter.ax,2.2007.0219.1100
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0015
Leadtek Stream Control,0x00200000,1,1,WFSCF.ax,1.00.0000.0003
LeadTek MPEG Video Encoder,0x00200000,1,1,WFVENC.ax,5.00.0000.1305
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Ulead DVB Parser,0x00200000,1,0,ulDVBParser.ax,2.00.0000.0017
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0015
Ulead Audio Dual Channel Filter,0x00200000,1,1,UAudioDCFilter.ax,1.00.0000.0002
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0015
DScaler Mpeg2 Video Decoder,0x00800000,1,1,MpegVideo.dll,0.00.0006.0000
VFW Sample Grabber,0x00200000,1,1,P1120Vfw.dll,1.00.0001.6784
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3243
IL FL Studio DXi,0x00200000,1,1,FLSTUD~2.DLL,1.00.0009.0000
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
IL Multi FL Studio DXi,0x00200000,1,1,FLSTUD~1.DLL,1.00.0009.0000
TrueMotion 2.0 Decompressor,0x00600001,1,1,tm20dec.ax,1.00.0000.0000
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,
MSScreen encoder DMO,0x00600800,1,1,
WMVideo9 Encoder DMO,0x00600800,1,1,
MSScreen 9 encoder DMO,0x00600800,1,1,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3243
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0015
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.6.1 Codec (1 Logical CPU),0x00200000,1,1,qcap.dll,6.05.2600.2180
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.6.1 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,
WM Speech Encoder DMO,0x00600800,1,1,
WMAudio Encoder DMO,0x00600800,1,1,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.3243
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
Ogg Vorbis (mode1),0x00200000,1,1,quartz.dll,6.05.2600.3243
Ogg Vorbis (mode2),0x00200000,1,1,quartz.dll,6.05.2600.3243
Ogg Vorbis (mode3),0x00200000,1,1,quartz.dll,6.05.2600.3243
Ogg Vorbis (mode1+),0x00200000,1,1,quartz.dll,6.05.2600.3243
Ogg Vorbis (mode2+),0x00200000,1,1,quartz.dll,6.05.2600.3243
Ogg Vorbis (mode3+),0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3243
DSP Group TrueSpeech™,0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3243
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3243
DV Audio – NTSC,0x00200000,1,1,quartz.dll,6.05.2600.3243
DV Audio – PAL,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Audio Layer3,0x00200000,1,1,quartz.dll,6.05.2600.3243
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Audio Layer2,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3243
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.3243
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming Capture Devices:
,0x00000000,0,0,
Realtek AC97 Audio,0x00200000,3,3,5.03.2600.2180
WDM Streaming Rendering Devices:
,0x00000000,0,0,
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,5.03.2600.2180
Video Capture Sources:
Creative WebCam NX Ultra (VFW),0x00200000,0,0,qcap.dll,6.05.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.3243
CyberLink Audio Renderer,0x00200000,1,0,CLADR.ax,5.00.0000.0807
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3243
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,5.03.2600.2180
Realtek AC97 Audio,0x00200000,17,2,5.03.2600.2180
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,5.03.2600.2180
--------------------------------------------------------------------------------[/code]
It could be that for some reason it is overheating when you try to do anything demanding. Try some software called SpeedFan to check the temperatures.
I’m not sure if your PC would freeze, but it could be the power supply unit (PSU) which has broken, and when components demand more power, it cannot handle it.
Post your temperature results please from SpeedFan!
Thanks for the advice. Here are the readings from that program, i’m not sure what it all means but im sure you know better than i do.
http://img440.imageshack.us/img440/1403/tempco8.jpg
Yeah, i’m pretty much with Thomas on this one, as far as overheating goes, the only culprit there would be dust. Clean out your machine, and if your still having problems that its your power supply. Not to get you down, or to jump to conclusions, but i had that problem once, and it was my powersupply.
Those readings are quite high, although everything except the core is acceptable. When you took the printscreen, had you just been playing a game, or had you just booted, or were you doing something non-demanding. I imagine that if it was either of the last 2, then your temps would rise when you started playing a game, and then the readings would be too high.
As suggested by Swansen, try carefully removing any dust from your PC, there is a hell of a lot that gets in the CPU heatsink I found, and removing that helped a lot.
