ok i have recently built my own pc(amd 3500, 6800 ultra, av8, 3200 corsair xl) and all works great apart from one thing when i as trying to play my games ie doom 3 ect the pc kept crashing straight to desktop or hung until i reset :eek: i have eliminated all the possible problems and discovered that it all runs fine when i just put one memory stick in or if i run the memory in single channel mode by putting them in memory sokets 1 and 3 or 2 and 4 ect but of course i would prefer if they worked in dula channel mode a it is much faster so i would be very appreciative if any one can help me out of this puzzling predicement ![]()
thanks nick :good:
I’d try bumping up the DDR voltage by 0.1V and see if that helps. DDR’s voltage is 2.5V, but you can up the voltage a little and it won’t nuke anything. I wouldn’t go much past 2.8V, however.
hi i would try looking through your motherboard manual (if u haven’t already) and is it one perticular stick that isn’y working or one perticular slot?? i would cheack all you memory slots work and all you ram is fine first. hope i helped Dave
ok thanks guys but bumoping up the ddr voltage didnt help
and i cant find any thing in the manual i am going to email abit to see if they can help do you thibk it could be a bios problem or a timming issue
