Hello All,
I am using a Intel 845GBV mother board. So far was using 256 DDR RAM. Now I got a new hard disk and a new memory stick of 1 GB. But when i use this new memory stick, i get a blue screen with the error message,
"A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you 've seen this Stop error screen restart your computer. If this screen appears again, follow these steps:
The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an update BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F& key was pressed - itwill silently disable ACPI and allow you to continue your installation.
So i decided to go ahead and try with the old RAM of 256 and it worked. I installed Windows Server 2000. Now I want to use the new RAM of 1 GB. What do I do? If i try to update BIOS, it gives an error that BIOS cannot be upgraded in Windows Server.
Please help.
Thanks,
Bidwan
