Me and a friend are looking for a case to build a nice portable frag box any links , ideas and, or suggested models? heres the mobo were gonna run unless anyone has anything thats got better reviews… http://www.newegg.com/Product/Product.asp?Item=N82E16813130529
The Antec ARIA is pretty popular, although it might be on the expensive side.
max12590 is right about the power supply: don’t use it if it’s included in a case. Aspire isn’t a brand of power supply I’d recommend either…at least if you value your investment much at all.
