yeah Tech’s right without knowing the exact spec of both DIMMs and viewing your motherboard manual, it’s difficult to say, however, just plug it in and see if it works, you won’t harm anything, just remember, while your inside the system and you don’t have an anti static wrist strap just touch an exposed metal part of the case every minute or so
BTW: installing PC133 RAM with PC100 RAM does work 9 times out of 10, however, your right about the RAM slowing down, thePC133 will run at the speed of the PC100 RAM, however, with a 1.1 Duron, i doubt you’ll notice the slow down as you will also be doubling the RAM
Well, I installed it and it seems to work. Is there a test program that can look at the speed of memory? The computer generally seems to run faster.
Just some details FYI:
The motherboard manual (for an M810LR-H) isn’t available somehow, so I used the M810LMR, V1.6 manual, although I have a 7.1A version motherboard. Anyway, since the board takes 133MHz memory, its should handle 100MHz memory easily - and now I see that it does. I imagine it must run slower, of course.
I looked up the markings on the two types of chips, but it was very hard to tell if they were compatible.
the only identifiable marks on the DIMMs or chips will be the manufactures part numbers, & each manufacturer make up their own part numbers, so, they don’t mean anything
