I just bought this new graphics card( http://www.bestbuy.com/site/olspage.jsp?skuId=6365391&type=product&id=1077627694525 ) i came home, turned on the pc, disabled the on-board graphics, shut down the pc, put in the new GeForce MX 4000, tested how it looked using madden(slight improvement), worked fine. next day turn on pc start up beashare to look for some electronics e-books, BOOM!, the screen goes black just like it just shut down or something, but i can still hear my music coming out of the speakers, after trying just about everything, power button monitor plug, ctrl-alt-delete, nothing, so i just turned off the pc by holding the power button. turn it back on came straight here before another “BLACK-Out”. did i do something wrong? what can i Do?
you should have posted before you bought the graphics card we could have suggested a better one. Any way trying taking it out and re-inserting it again.
oh and make sure all the wires to and from the graphics card is inserted correctly.
there are no wires, at all
you have no wires from the graphics card to the monitor?
no i mean from like the graphics card to like the power supply or something
