more fan connectors
well i was after a perspex side for my black atx case but couldnt find one so went to a local shop called pimped up cases were they have airbrushed cases etc and picked up a full perspex 2 tone case for 60quid and as it was the one on display that the owner used to have he said i can keep the 5 akasa 80mm fans and the 5 chromegame covers that were on the fans . so well happy will get picks when its done.
hopefully the 5 fans should help cooling alot as there is 1 on top 1 front 1 back and 2 side .
bargain of the day
quick question as my new casae has 5 fans on it allready mu mobo can only take 4 and that includes cpu so i only have 3 out of the 5 working can u get adapters to plug two together or not. also the fan on the front has an extra ring round it which is eant to light up im not sure where this plugs into on the mobo . any one enlighten me on this thanks.
bargain of the day
what you need is a fan splitter adapter (scroll down) Akasa Cables
is this the one
3 Pin Fan Splitter 3 Pin Female to 2x3 Pin Male
so i can have 2 going to each socket.
anything on the ring light i mentioned i dont no were it can possibly plug into and it will ony reach as far as the hdd led but wont fit any if them.
You also might consider getting a fanbus. You’d be able to control the fan speed from a panel on the front of your case. A second option would be to run the fans straight from the power supply. The fan headers on a motherboard aren’t designed to run a ton of fans off them, so too much drain on them can blow those headers. Needless to say, it’s strongly recommended that you not run any fans over 80mm off the headers. Also, if they’re high CFM fans (like the Vantec Tornado), you’re also better off running them straight off the power supply.
iv only got 2 out of the 5 running from mobo i got 3 runing off a silver stone panel . the panel comes with a hdd,cpu,sys fan wires for controlling there speed so i just pluged them into that. is that ok.
Yup. Those are just labels. All fans have to conform to certain standards, so it won’t break anything if you’re not using a “cpu” fan.
cool do u no anything about how i can get the light on the front fan to staart working as its too short to reach anywher on the mobo
