Motherboard for Ballistix Memory
First off…Been reading these forums a while now, thought I’d finally register… So.. Hello :slight_smile:
I currently have a AMD 5000+ Black Edition, 8800 GTS 320MB.
Planning on upgrading my ram to 2x1GB Crucial Ballistix 800mhz
My current motherboard died, an ASUS M2N-E, and so far taken nearly 3 months to get a return. I think I will just buy a new one, as I am tired of waiting. Can you recommend a motherboard I should get as I dont think the M2N-E can handle Ballistix memory anyhow.
I do overclock, but not to the extreme. Will possibly go SLI in the future. Thanks for any advice. Cheers
Great Board:
Newegg.com - MSI K9N SLI Platinum AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard - Retail
Good heatsinks to CPU for your overclocking… of course a good CPU fan/heatsink will additional be needed!
Supports your ram
[COLOR=“YellowGreen”]Supports SLI
Pretty CHEAP if you ask me
Another [COLOR=“Red”]HOT ONE:
[url=http://www.newegg.com/Product/ShowImage.aspx?Image=13-131-011-02.jpg%2c13-131-011-03.jpg%2c13-131-011-04.jpg%2c13-131-011-05.jpg%2c13-131-011-06.jpg%2c13-131-011-07.jpg&S7ImageFlag=0&Depa=0&Description=ASUS+M2N32-SLI+Deluxe+Wireless+Edition+ATX+AMD+Motherboard]Newegg.com - Computer Parts, PC Components, Laptop Computers, Digital Cameras and more![/URL]
Don’t buy that board for an SLI setup. It has the 570 chipset in it which is a horrible performer when it come to SLI. I would recommend that you actually go with a crossfire setup instead of an SLI setup if you plan on using your Athlon proc.
What about the 680i’s?
I don’t believe I’ve seen an AMD board with the 680i. I haven’t looked all that hard for one, but I would think I would have by now. If you can find one post it please. Thanks :slight_smile:
